http://img864.imageshack.us/img864/472/793492199.gif
Microsoft® Windows XP SP3 Corporate Student Edition July 2011
http://img10.imageshack.us/img10/428/takff7.jpg
this windows was made with xp pro student edition sp0 RTM 32bit as the source disk,
with Sp3 Build 5512 added and upto date hotfixes added
no need for any wga cracks with this one
it passes online as fully Genuine
(student edition ****d + proper student key)
the cd-key is slipstreamed into the cd so no need to put when installing
from system bootup
tcp ip = 16777215
uxtheme applyed
Default windows language ENGLISH/UK
please change to your own language when installing.
you can also use 'Regional and Language Options' after if need
be in Control panel.
i burned the iso image with nero.. this will just about fit on a 700 MB cdr-rom..
please do a clean install from system bootup
with this windows disk. this is not a upgrade disk.
ADDED TO THE INSTALL DISK
Framework all in one 2.0 - 4.0
Internet explorer 8
Windows media player 11
Directx 9 Runtimes 9.29.1974 April 2011
Directx Managed Code 1.1.0
Flash 11.0.1.60
Shockwave 11.5.9.626
Java 6 update 26
Winrar 4.0.1 regged
Lclock 1.62b
c++ runtimes 2005 & 2008 & 2010
Msn.Live.Messenger.9.0.14.0.8117.416 ***-setup on desktop
REMOVED FROM THE INSTALL DISK
Music Samples
Windows Messenger 4.7
Tour
REMOVED FOLDERS FROM THE INSTALL DISK
SUPPORT , VALUEADD , DOCS , WIN9XMIG , WIN9XUPG , WINNTUPG
Driverpacks **** 10.06
DriverPacks **** is an integration program that will take
individual DriverPacks and integrate them into a local
32-bit Windows source for installation.
DRIVERPACKS ADDED
MassStorage 11.06 txt mode
(sata + raid)
THE UPDATES
(hotfixes)
SFC (windows File Protection) Disabled
Numlock off default
Classic control panel Enabled
updated windows hotfixes till July 13th 2011
updated Flash 11.0.1.60
How To Use
Burn the image using the software you like at a slow speed
say about x4 or x8
as this CD is bootable.
Install as you would an original CD from system bootup.
leaving the disk in the drive and reboot pc.
booting from cd rom drive first before harddrive
If you have xp installed already your advised to backup
your drivers first before install. example using driver genius.
as only "MassStorage 11.06 txt mode (sata + raid)"
and "basic xp drivers" are on this cd-r disk
http://img842.imageshack.us/img842/6414/whalutyv.png
للتحميل باقصى سرعة استخدم اخر اصدار من برنامج IDM من هنا
لفك الضغط بدون مشاكل استخدم اخر اصدار من برنامج WinRAR من هنا
http://img502.imageshack.us/img502/4374/5dy06260.png
النسخة على رابط واحد
filekeen
http://takemyfile.com/1392268
filerace
http://takemyfile.com/1392269
تقسيمة 200 ميجا
hotfile
http://takemyfile.com/1392264
http://takemyfile.com/1392265
http://takemyfile.com/1392266
http://takemyfile.com/1392267
ul
http://takemyfile.com/1392230
http://takemyfile.com/1392231
http://takemyfile.com/1392232
http://takemyfile.com/1392233
mediafire
http://takemyfile.com/1392270
http://takemyfile.com/1392271
http://takemyfile.com/1392272
http://takemyfile.com/1392273
megaupload
http://takemyfile.com/1392251
http://takemyfile.com/1392252
http://takemyfile.com/1392253
http://takemyfile.com/1392254
10upload
http://takemyfile.com/1392279
http://takemyfile.com/1392280
http://takemyfile.com/1392281
http://takemyfile.com/1392282
fileserve
http://takemyfile.com/1392221
http://takemyfile.com/1392222
http://takemyfile.com/1392223
http://takemyfile.com/1392224
enterupload
http://takemyfile.com/1392226
http://takemyfile.com/1392227
http://takemyfile.com/1392228
http://takemyfile.com/1392229
rapidshare
http://takemyfile.com/1392247
http://takemyfile.com/1392248
http://takemyfile.com/1392249
http://takemyfile.com/1392250
ifile
http://takemyfile.com/1392255
http://takemyfile.com/1392256
http://takemyfile.com/1392257
http://takemyfile.com/1392258
jumbofiles
http://takemyfile.com/1392260
http://takemyfile.com/1392261
http://takemyfile.com/1392262
http://takemyfile.com/1392263
:z026::z026:
