الموضوع: Transitional Devices (Connecting Words)
    مشرفة قسم الضحك والترفيه
    الحالة : سارة غير متواجد حالياً
    رقم العضوية: 330
    الإهتمامات: الفروسية
    السيرة الذاتية: كل الاحبة اثنين اثنين متجمعين في الهوى دايبين على ايه تكشر وليه تفكر ده العمر كله يومين
    العمل: مهندسة
    العمر: 33
    معدل تقييم المستوى : 660
    Transitional devices are like bridges between parts of your paper. They are cues that help the reader to interpret ideas in the way that you, as a writer, want them to understand. Transitional devices help you carry over a thought from one sentence to another, from one idea to another, or from one paragraph to another with words or phrases. And finally, transitional devices link your sentences and paragraphs together smoothly so that there are no abrupt jumps or breaks between ideas.
    There are several types of transitional devices, and each category leads your reader to make certain connections or assumptions about the areas you are connecting. Some lead your reader forward and imply the "building" of an idea or thought, while others make your reader compare ideas or draw conclusions from the preceding thoughts.
    Here is a list of some common transitional devices that can be used to cue your reader in a given way.
    To Add:
    and, again, and then, besides, equally important, finally, further, furthermore, nor, too, next, lastly, what's more, moreover, in addition, first (second, etc.),
    To Compare:
    whereas, but, yet, on the other hand, however, nevertheless, on the other hand, on the contrary, by comparison, where, compared to, up against, balanced against, vis a vis, but, although, conversely, meanwhile, after all, in contrast, although this may be true
    To Prove:
    because, for, since, for the same reason, obviously, evidently, furthermore, moreover, besides, indeed, in fact, in addition, in any case, that is
    To Show Exception:
    yet, still, however, nevertheless, in spite of, despite, of course, once in a while, sometimes
    To Show Time:
    immediately, thereafter, soon, after a few hours, finally, then, later, previously, formerly, first (second, etc.), next, and then
    To Repeat:
    in brief, as I have said, as I have noted, as has been noted,
    To Emphasize:
    definitely, extremely, obviously, in fact, indeed, in any case, absolutely, positively, naturally, surprisingly, always, forever, perennially, eternally, never, emphatically, unquestionably, without a doubt, certainly, undeniably, without reservation
    To Show Sequence:
    first, second, third, and so forth. A, B, C, and so forth. next, then, following this, at this time, now, at this point, after, afterward, subsequently, finally, consequently, previously, before this, simultaneously, concurrently, thus, therefore, hence, next, and then, soon
    To Give an Example:
    for example, for instance, in this case, in another case, on this occasion, in this situation, take the case of, to demonstrate, to illustrate, as an illustration, to illustrate
    To Summarize or Conclude:
    in brief, on the whole, summing up, to conclude, in conclusion, as I have shown, as I have said, hence, therefore, accordingly, thus, as a result, consequently, on the whole
    الحالة : king-of-nothing غير متواجد حالياً
    رقم العضوية: 2449
    الإهتمامات: no
    العمل: mafe
    العمر: 42
    الحالة الإجتماعية: أعزب
    معدل تقييم المستوى : 265
    يعطيكي العافية
    King of Nothing
    1. Confused Words
      بواسطة سارة في المنتدى ملتقى تعلم اللغة الانجليزية English Language Forum
      آخر مشاركة: 02-17-2011, 07:27 PM
    2. great words.......
      بواسطة محمود عبد المعطي في المنتدى ملتقى تعلم اللغة الانجليزية English Language Forum
      آخر مشاركة: 12-14-2010, 06:01 PM
    3. كلمات من ذهب-words of gold
      بواسطة الصقرالحنون في المنتدى ملتقى تعلم اللغة الانجليزية English Language Forum
      آخر مشاركة: 10-12-2010, 09:43 PM
    4. Low-tech, low-cost solutions connecting India farmers (AFP)
      بواسطة Mgtrben news في المنتدى World News in English Language
      آخر مشاركة: 09-03-2010, 09:15 AM
    5. Poll: Americans connecting with government online (AP)
      بواسطة Mgtrben news في المنتدى Tech News World 24/24
      آخر مشاركة: 04-27-2010, 07:50 AM
